GSTdOff
- 99
- 0
- Dec 30, 2003
Florence,
Arizona
Logue do you have the stock BOV? If you do and you have the Wastegate Solenoid Restrictor removed, your running at your boost limit.
I just replaced that thermostat with a new one. One other thing I forgot to mention. It had a small leak that I put some of that radiator stop leak stuff in and fixed a couple weeks ago. Is there a chance that's plugging something else important? or is it more likely the HG.ADrewzki said:Maybe you could swap a different thermostat in and test it. Could be your old one is, well, OLD and on the fritz.
The car doesn't puff white smoke after I drive it and the compression test came up with 190 on all cylinders?mitsutuner said:merry christmas, you have a blown head gasket my friend.
white smoke is steam--burning coolant that got by the gasket & into the combustio chamber.
cofirm with compression test.
Happy new year!
The car has 61,000 on it and I'm sure that's how old the water pump is. If it was failing wouldn't it be spitting coolant out or something?ADrewzki said:Yeah, sorry. I see now that you did replace the thermostat. As far as I know, all the store bought stop leak products are liquid based so they're not going to be able to clump together big enough to block up anything. I don't think it's the head gasket because I fail to see how a blown hg could cause your coolant to overflow. You'd probably get oil in your coolant and that white smoke but the overflowing thing doesn't fit into the equation. Could it be possible that your new tstat is defective? I'm really at a loss as to why this is happening.
Edit: I just thought of something. Your tstat might be fine but maybe it's your water pump that's flaking out. How old is it?
96tsiaddict said:The car has 61,000 on it and I'm sure that's how old the water pump is. If it was failing wouldn't it be spitting coolant out or something?
96tsiaddict said:I sure hope it's not that but I fear you are right. The overflow tank after warming up starts bubbling from the air coming into it but as soon as it starts to cool down it stops so I'm wondering if possibly the hole opens when it's hot and then it is closed when I do the compression check because it has cooled down to much. Any suggestions on what HG. I'm hoping to do some mods including a 16G and maybe the stroker kit so I don't have to worry about crank walk. What head gasket would hold the most boost. And any other ideas on this problem?
Well, I already replaced the cap and the fans are working fine so I'm narrowing it down quickly to the HG. If the water pump wasn't working would the engine heat up normally and sit in the normal area until the coolant is low enough to overheat though? I would think it would overheat right away. What about a certain type of HG? anyother thought is I'm thinking about putting a 1g head on at the same time but would it be better to get mine ported or just do the 1g engine swap now?rebuilt65 said:Try changing the cap.(I know, but I was a victim once of a faulty cap)
1. Most cars steam out of the exhaust when first started and the catalytic converter hasn't heated up.
2. If the cap is bad, bubles will appear in the overflow tank when you first start up.
3. A bad cap will not hold pressure, allowing the coolant to flow into the overflow, and then eventually the car will overheat.
4. Are the fans working?Turn of the A/C, both should come on. If the passenger fan does not cycle on its own, and only with the a/c system, the radiator fan switch is bad.
These things are the cheapest and easiest to change/check
Good luck
