Quickie: What size is the oil filter housing cooler line in/outputs
Logikal
54
Sep 22, 2004
West Middlesex, Pennsylvania
I am making an oil cooler setup for my car, using all earls summit fittings, an-
Was wanting to make sure
What size are the input/output holes for the oil filter housing for the cooler lines, someone said 16mm but the evo guys say it is 18mm :\ Can anyone clarify this for me?...
thanks
16x1.5 and if you would have looked in the thread directly below this one you would see it in there.
And if you looked in the thread directly below this one you would realize that he was the one that said that to begin with. He is just trying to double check his info to make sure it is correct.
Dan
I think it's 16x1.5, but I'd have to double check my connectors from DSMotorsports to be sure.
