quick question
4g63ttuner
49
Apr 8, 2009
omaha, Nebraska
what lines on the throttle body for coolant go to? upper and lower.
also there is a feed or return line that goes by the oil filter that runs behind the turbo and goes up by the coolant feed line for the turbo. were does that line go to?
the is were it comes from:
this is were it goes up to:
please and thank you
And the lines under the TB aren't from the heater core are they?
No they are for the FIAV valve.
Here is how everything goes:
#35 connects from the thermostat housing to the FIAV and #36 connects from the water pipe to the FIAV. #40 connects from the oil cooler ring to the water pipe and #'s 41, 43, and 39 connect from the oil cooler ring to the thermostat housing.
It runs from the oil cooler ring up to the thermostat housing.
Also the use of proper english, punctuation, and spelling will get you a long ways on this forum. The improper use won't get you anywhere. Next time please put some effort into it. Lastly just a tip, name your thread something more descriptive like "Where do the coolant lines on the throttle body go?" instead of "quick question". :thumb:
