quick question about cooling lines??
diamondsm
107
Mar 27, 2010
port orchard, Washington
1990 eagle talon tsi
k so this is the last thing before i start the car so want to get this figured out tonight if possible
there is three spots for lines to go on my thermostat housing the very top i'm sure is the overflow but not sure witch line go's on what one for the other two?? i have a line going off the turbo and the line coming from the oil cooler witch one go's on the middle and what one go's on the bottom??
i could not find a pic of my thermostat housing but this is how the lines are on mine as well??
The line at the bottom right leads to the turbocharger coolant line.
The line at the back of the housing, leads to a section of piping that comes off of the initial coolant piping from the aluminum pipe (that sits in front of the engine block, below the manifold that leads to the water pump and the lower radiator hose), which I'm pointing at. Sorry for the bad picture.
Since you've got a '90, like I have, here's another picture that might help you out.
There are two on the back of the thermostat housing and neither leads directly to the water pipe. The large one passes through the heater core before returning to the water pipe extrusion while the other goes to the throttle body and the FAIV.
These are probably helpful links as well:
http://www.dsmtuners.com/forums/152482677-post5.html
http://www.dsmtuners.com/forums/152482811-post10.html
