Quick intake install question
Shmikey
Dec 5, 2005
Boca Raton, Florida
I have a quick question on intake installation. I am putting in my 2g Curved Intake Pipe from Dejon tools, now where do the 3 rubber hoses that normally fit in the stock intake go??? (not the bov recirc)
right now I just have them blocked off but i was wondering what they are/what I should do with them?
Hook one up to your valve cover like ^ said with a small fuel filter of some sort in between VC and intake pipe. The other tube sounds like charcoal canister, which can be left unhooked but plug the intake pipe hole.
On a 1G there is the valve cover breather, which you should continue to use. There is the evaporation canister line which is Ok to unhook and reroute or remove. Lastly there is the BCS line which you can remove as well.
Any open ports on your intake tube should be covered to prevent unmetered air from entering.
