2G Questions on Building my 2G
AmniPower Noob
Aug 22, 2019
tampa area, Florida
hey all,
I am new to DSM and cars in general. Of course i have a general knowledge. I have researched a lot in the past month or so, so i understand a lot more than i did before. The guides on this website rule. I got my fathers old 2G 96 Eclipse GST that he blew an engine in. He blames it on the guy who owned it before him but whatever.
He got a different, more stock, engine and a bunch of OEM/Factory parts as he was going to convert it back to avoid blowing another engine. then he never touched the car again, never to be put back together, until now at least. He said there was one problem that he thinks is the ECU or a fuel sensor, when he was going down the road the car would act as if it was fuel starved and kind of stall, but it would stop after a moment. I have no clue if the ECU has an EPROM on it, i have to check it and that will have to wait a few days.
He ported a lot of parts that never touched the oil, this includes a 1G cam sensor, good thing it was never started because he never the firing order on the new engine was never changed.
I will have the car up and running by at most November 2019, i need to save up to buy fluids and do general maintenance like Mystery Oil in the head an manually cranking as it has sat for 6 years+.
A few side notes are
it is not running a stock inter cooler, though i have one and all the piping necessary to run it + a factory BOV.
No stock radiator, i have one from cxRacing
I need to check to see if the turbo is stock, the one that was on it was a Chinese turbo and the bearing on that one are going bad
I have a 1g Cams and Throttle body, i don't get the idea behind converting them
I have a stock wiring harness as the one on the car is beat up, has no knock sensor, and in general is probably time to replace. (if it comes to my attention that the 1G parts are better ill follow the converting guide on DSMTuners).
I have not done a compression test or a leak down test, and if my car fails them i wont be doing much with it until I get that fixed. Id have to get garage space anyway and if i did, i would wanna do an engine overhaul, as i am young and want my car to go fast and handle more boost.
I already have a boost gauge and a manual boost controller, though my father says its Chinese so ill probably change it out.
I have a K&N air filter on it, no bracket to support it and a stock air filter to turbo piping.
The evap system is removed but i have the factory purge valve and might reinstall it if necessary
I have an aftermarket BOV that feeds into the turbo (I'm young but not stupid to atmosphere it), though again its not name brand and will likely be replaced.
The crank shaft is pulling from atmosphere though everything i saw online says it is not a good idea, so ill use the factory piping for now to run into the PCV from my intake.
This is my first dive into any sort of a Mod scene and i'm still very noobish, please go easy on me
I'm following the guide on basic horsepower increase and my goal is 300 hp, its a FWD and and really cannot drag well
I am putting together a lists of parts i've found online, following the hp increase guide though i am still researching this.
https://www.dsmtuners.com/threads/dsm-maintenance-guide.476550/
https://www.dsmtuners.com/threads/basic-horsepower-ugrades-2g-4g63t.480196/
Stage: Maintenance :)
About $3000
As recommended by the guide, the timing belt should be checked. on the GST the timing belt is brand new. Also check and replace the following with oem; https://www.extremepsi.com/store/Extreme-PSI-Timing-Belt-Kit-Mitsubishi-Eclipse-90-99.html
1. Timing belt tensioner
2. Timing belt tensioner pulley
3. Timing belt idler pulley
4. Timing Belt tensioner arm
5. Water Pump and Gasket/o-ring
$531.25 with balance shaft eliminator
For tool to do timing belt buy https://jnztuning.com/product/jay-racing-timing-belt-tools-kit/
$50.00
crank pulley/harmonic damper
oem, could fly apart $102.07
https://shop.advanceautoparts.com/w...&langId=-1&searchTerm=crank pulley&isFitted=1
aftermarket $379.00
https://stmtuned.com/products/fluidampr-1g-2g-dsm-harmonic-balancer-crank-pulleys
Gasket replacement 70.99 for a full set
https://partsology.com/gasket-seali...j19JFKir5oVhm3ooofxl_penupze0JaBoCWE8QAvD_BwE
ecu needs an EPROM for tuning software, might have one. A kit and a convert costs $740
Spark plugs need to be changed to copper core NGK BPR6ES and gapped to 0.028 to 0.030
around $10 for a set
Boost leak test tools $49.99
https://www.extremepsi.com/store/Torque-Solution-Boost-Leak-Tester.html
Take a bottle of soapy water and spray down where a leak could happen
Check the turbo for shaft play every time you replace oil. Take needle nose and grab the compressor nut and shake. If a lot it's bad.
compression tester $40
leak down tester $50
https://www.harborfreight.com/cylin...Fjw7D0TineTGRLs3y9SzIzXOQSOUycOxoC9kYQAvD_BwE
How to: https://www.dsmtuners.com/threads/compression-and-leak-down-testing.338152/
Change transmission fluids.
$50
Fuel filter $23.99
https://www.autozone.com/filters-and-pcv/fuel-filter/duralast-fuel-filter-ff641dl/196176_908077_6138
Check brake and clutch fluids
Check pcv System and add a check valve $2
https://www.usplastic.com/catalog/item.aspx?sku=64175
Replace ball joints and full arm case $103.98 (sold separately )
https://www.summitracing.com/parts/...ubishi/model/eclipse/submodel/gst?prefilter=1
New tires $591.96 full set not installed and factory
https://www.tirerack.com/tires/tire...ear=1996&autoModel=Eclipse Turbo&autoModClar=
Stage 1 :)
about $6000 without tools and most install kits
Need to make a bracket for the k&n air filter
Hard Intake pipe $262.33
https://wheelwell.com/shop/injen/ai...96&make=Mitsubishi&model=Eclipse&submodel=GST
I already have a manual boost gauge
I Already have an aftermarket BOV, however a name brand would be better. Though most just make noise, so need to search but most around $400
I already own a Manual Boost Controller but i might need to buy another one about $150
https://www.extremepsi.com/store/Manual-Boost-Controllers/
How too: https://www.dsmtuners.com/threads/best-way-to-install-a-mbc.237982/
Exhaust needs to be upgraded to 3"
Cat back $620
https://wheelwell.com/shop/thermal-...96&make=Mitsubishi&model=Eclipse&submodel=GST
Catalytic converter $109.99
https://jnztuning.com/product/vibrant-round-metal-core-catalytic-converter-3/
Down pipe $351.20
https://www.extremepsi.com/store/Apexi-GT-Downpipe-Mitsubishi-Eclipse-GST-95-99-Turbo.html
https://www.summitracing.com/parts/apx-145-km02
Manifold $429.00 with bolts
https://www.extremepsi.com/store/Fo...eat-Shield-Mitsubishi-Eclipse-90-99-SALE.html
O2 housing (ask dsm tuners if this exhaust works before buying. the inlet for the down pipe is 2.4 inches and outlet is 2.8 inches while converter is 3 inches) $109.99
https://www.maperformance.com/products/megan-racing-ss-turbo-outlet-o2-housing-evo-viii-ix
https://www.extremepsi.com/store/Me...tlet-O2-Housing-Mitsubishi-Eclipse-90-99.html
190 LPH Fuel Pump without wiring kit $90.00
https://www.extremepsi.com/store/product.php?productid=16311&cat=2376&page=1
https://www.dsmtuners.com/threads/evo-fuel-pump-install-better-than-walbro-190-on-2g-awd.231405/
I don't need inter cooling piping.
Turbo is a little complicated, i need to install an air cooled oil filter housing.
Turbo: $1,299.00 without internal Wastegate (+$100)
https://stmtuned.com/collections/1g...63-bolt-on-turbos/products/fp-black-dsm-turbo
Oil filter housing (air cooled): $127.94
https://stmtuned.com/products/oem-mitsubishi-evo-iii-oil-filter-housing
Cooler 7-bolt:$289.00
https://stmtuned.com/collections/1g...tm-7-bolt-4g63-race-dsm-engine-oil-cooler-kit
Feed Line: $20.00
https://stmtuned.com/collections/1g...tm-4an-stainless-braided-turbo-oil-feed-lines
Clutch Upgrades:
Heavy Duty Pressure Plate: $206.00
https://www.extremepsi.com/store/ACT-Heavy-Duty-Pressure-Plate-Mitsubishi-Eclipse-90-99-SALE.html
Clutch Disk Full/Kevlar: $195.00
https://www.tmzperformance.com/shop...laser-evo-1-3-galant-vr4-3si-platform-na-fwd/
Is this clutch a puck clutch? i have no idea what that means, would it be good for a 300hp range car?
https://www.dsmtuners.com/threads/which-clutch-would-be-best.434549/
It is recommened that i get a LSD, comes with install kit: $1,234.95
https://www.tmzperformance.com/shop/quaife-lsd-front-differential-for-fwd-dsm3000gt-qdh7b/
