some questions on 2g awd build
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
i building a 95 awd from a scratch,and i got some questions about brake cylinder and the routing f harness.
I got a 98 fwd (gst) as a donor car.so,i changed the front hard brake lines.and when i came up to the brake cylinder,i got two enpty holes in it.(the holes are for a hard line)I Looked at the proportioning valve where all the hard lines are connected,and the proportioning valve from 95 is different then 98. because 95 got only 4 lines comin into the proportioning valve and the one from 98 has 6 lines comin into the proportioning valve. So m i missing something here?
another thing is,i don't know ,which way the harness ,that comes from the passenger fender goes accros the front end? I got the pictures about my first and second question
come on guys throw up some advice,because,thats the only thing ,that keeps me away from putiing my engine in it....:cry:
well after a looooong search i found the answer to my first problem. I figure it out ,that i got an ABS system in my 95 gsx.So i will fix that problem by deleting abs and goin non ABS.:hellyeah:
quote:another thing is,i don't know ,which way the harness ,that comes from the passenger fender goes accros the front end?
I'm just guessing, but I would say it goes along the bottom of the condenser kind of the way you have it going in the picture. As long as it's on there and securely connected, I'd say you have nothing to worry about.
the proportioning valve on picture is for vehicle with ABS ,if you don't have abs then you need 6 lines proportioning valve
on yours pictures two lines from brake cylinder would go strait to abs unit located almost under driver headlamp
