questions on best head set up?
starscreem
128
May 2, 2005
hoffman estates, Illinois
i know there is now best set up every one has there own opinoin, but im just not to sure what i should get in valves and springs. Im going with 1mm over and nitrated i know that, but who makes the best valves. manley, ferrea, si, and also who makes the best springs manley, crower, si, or ferrea. i have the comp 101200 cams( not in yet). and i want to make a good 400-500hp from my set up. my curint lifter are about to go so thats why im just going to rebuild her. im also in the works of building a 2.1 destroker for the head. should i use a 6 bolt head or my 2g head. and what stage port job do u think i need i live about 15 min from ams so i can get all my work done there. but i also no there machinist they use here in the chi from apexi so i no i can get the work done i just need advise on parts.
If you want to rev higher than 8800 go with SI dual springs. As far as valves IMO best on the market are Ferrea. A close second is Manley. If you are going to be doing a good deal of porting best head to go with is going to be a 7bolt. To use everything to best of it's ability you will also want a 5 angle valve job. Also remember is you do indeed go with the 7bolt head you will need to drill out the head stud bolt holes to fit the 6 bolt head studs. Hope this helps.:thumb:
Supertech Duals and you cant go wrong
Supertech 1mm over or stock sized valves are great
on our shop evo and the 903 whp customer car we both use Supertech valvetrain components and couldnt be happier
Eric
Eric
I went with Supertech as well for my build, and used SI valves.
Dan
