Questions about coil on plug ignition
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
Is this true: difference between 2.7 and 3.5 coils is that 3.5 coils are higher output coils and used for 500+ hp applications 2.7 are good up to 500 hp? im running about 350whp now so id go with the 2.7 coils right?
also are cop better then wires and stock coil pack? i was thinkin to buy a cop because my stock coil pack is goin bad on my car so i think and i keep getting a check engine light for p0304 and p0300 misfires. mechanic said its my coil pack since i replaced the spark plugs and wires and still got misfires. i gapped the plugs at .026.
these are my mods:
Forced Performance Green 730cfm Turbo with external dump
Dejon intake pipe/K&N FIPK
Walbro 255 fp
660 injectors
Tial waste gate
Ported manifold
Greddy oil catch can
Greddy type S BOV
Greddy Large Intercooler Kit
Greddy IC pipes
Electronics:
Greddy profec b boost controller
Greddy 60mm silver face boost gauage & Greddy ext temp gauage
HKS turbo timer
Jumptronix air/fuel meter
Apexi S-afc
Full 3" Turbo Exhaust:
Hahn 3" DP~Hi Flow Cat
Thermal 3" exhaust with 5" tip
If you would like to upgrade your coil without going cop MSD sells a direct replacement 4 post coil that will work well with the stock set up. I would do that since you said your coils going out.
did you get the alternator? if not whats the hold up on at least getting it tested again? or if you have a voltage meter just hook it up to the charge back wire and see what voltage its putting out
