extending ignition coil plug need advice
pandaman1130
37
Sep 22, 2012
worcester, Massachusetts
Hi guys any help will be appreciated . I just relocated my ignition coil from the center of my intake manifold to the top of the driver side motor mount . The only issue i have at the moment is were the ignition coil was originally based the ignition coil harness plug won't reach were it currently sits . what would be the best way to extend this plug ? Ive searched on ignition coil relocations that have been done and couldn't find any detailed information on how the plug was extended to reach were it has been relocated . Heres a picture hope this helps . i would like to extend the plug about 6 to 8 inches enough slack to play around with the relocation if i decided to move it somewhere else . :hmm: i also have a transparent timing belt cover to go over my cams so the the wires won't get in the way of the cams as it looks in the photo also try not to mind the way the shaved valve cover looks in the photo its actually really smooth and has no dings or blemishes LOL :thumb:
Solder in wires the correct length, one at a time. It's straight forward, nothing special about it.
^^^^^ What he said . I would also recommend using marine grade heat shrink tubing to insulate your soldered wires instead of electrical tape way better and cleaner
