questions about a 97 socketed ecu.
D Loco
57
Jan 29, 2012
Noble, Oklahoma
a buddy of mine has 2 socketed ecus one with a 97 stock eprom chip and 95 eprom chip off a gsx. he said he'ld just toss me one but i was wandering ca u put on in a 1g 90 and wut kinds of supportive mods would u need?
you will have to have it tuned for your cars specs or get dsmlink and tune it yourself. the point of eprom chip is that it gives u the ability to "tune" your car. There are companies that u can send it to and there are set ups you can buy like DSMlink ECUlink that allow you to do it yourself. Most say it's the best mod to do to ## DSM and even though I have not done it I would have to agree based on my research and other peoples testimony.
Well, yes, seeing as '95's were the only EPROM ECU's.
Ok that makes since. I would assume that might be tricky to find without getting the 95 ecu LOL, but the again I guess you could just burn a custom chip to stock levels and use that.
An off the wall question does anyone know if you would have to change the firing order on a EPROM conversion for a 97 (if you were to use the stock chip) like you do when you run a 95 ecu in a 97-99 or is that controlled by a different part of the ecu.
i thought there was one year they came stock with an eprom he said both ecu's were socketed and out of a 97 said he had a 95 eprom chip but didnt know if u could put them in a 1g. appreciate the links and help.
