question with fuel filter replacement
gstowner
246
Nov 13, 2004
Creston, Iowa
Im having some difficulties getting the the eye bolt of the top part of the filter I have the 3/4 wrench below to counter it and not bend the fuel lines but it will not budge at all. Is it supposed to be on there that tight? I dont want to force it and bend the lines or break something. Anyone else have this problem?
I know this is an older post but I thought some expirience that I had the last couple days might help others.
I used these wrenches as opposed to the flared wrench or line wrench.
Craftsman 3 pc. Extreme Grip Wrench Set, Metric - Model 42513 at Sears.com
or search google --> Craftsman 3 pc. Extreme Grip Wrench Set, Metric
These seemed to get the grip that I needed for that bottom fitting. When I initially tried this with a flare wrench It started to strip the fitting. I attribute this to a cheap brand of wrench.
For the top one, I ended up pulling the fuel line from the fuel rail(I needed to anyway due to some new injectors) so I didn't have to fight with the upper fitting/banjo bolt.
This helped considerably since I was able to get the leverage I needed when it was out, though still not that easy.
I also had to pull the battery tray support and evap can which were both royal pita's.
For this, I had to bend the tray support after removing the two bolts farthest from the firewall. This allowed me to get to the evap canister I was then able to get the bolt closest to the firewall that holds the evap canister. The first bolt for the evap can should be accessible, though still a pain to remove.
Hopefully this helps others if when they change out the fuel filter.
