Fuel pump Replacement Question
ryankreps
Jan 12, 2007
dallas, Texas
I just bought a 95 eclipse n/t, no mods yet, about to replace the fuel pump and im wondering which pump i should put in it. would it hurt to put a high flow fuel pump or should i wait for mod?
I would say, if you're increasing the boost, put a higher flowing fuel pump. Like a Walhbro 255lph.... If you're planning on running stock boost, get a stock pump.
In case you didn't see in his post, he has a n/t.
I really don't see any reason why you would need a bigger fuel pump unless you plan on boosting your car :thumb:
He is N/A.
And deffinatly dont put a 255 in a car with stock fpr. For a non turbo car i wouldnt worry about a higher flowing fuel pump yet. I dont know n/A 2gs but you should be fine with a stocker or maybe a used stock turbo fuel pump may fit and flow more, not sure on that though i would look into it, but then again that may also call for a afpr.
