XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
I've been a bit confused about how to properly adjust the BISS on my '92 Talon TSi. I realize that to do it properly you have to ground 2 connectors to disable the ECM's auto idle adjust and use a tachometer to adjust the BISS. What I'm confused about is whether adjusting the BISS without grounding these 2 connectors will "confuse" the ECM and result in poor idle control even if it seems to work for a while, and if you literally MUST ground them to properly set idle and can't do it otherwise no matter how finely you set the BISS?
The background for asking this is that I had both rough idle and poor fuel consumption so I recently removed and overhauled the entire intake and exhaust systems, cleaning everything up really well, replacing all gaskets and o-rings, vacuum hoses and even the throttle shaft seals, putting in a new O2 sensor as the old one wasn't working, having the injectors professionally cleaned, etc., yet I'm still experiencing rough idle and poor fuel consumption, which I'm guessing is due to either an improperly adjusted BISS or faulty IAC and/or FIAV. But I want to start out by first properly adjusting the BISS, and see if that fixes it, and if not only then moving on to other possible causes.
Btw, not asking anyone to diagnose my issues, but what tend to be the most common causes of rough idle and poor fuel consumption in this particular model at this point in its service life, over 31 years now? When I tested all the sensors either the fuel or EGR solenoid (I forgot which but I have it written down somewhere) gave out of range readings. Could it be this? I mean the ones attached to the firewall on the driver's side that are connected to the fuel regulator and EGR value via vacuum hoses and to the ECM via cables.
Btw I overhauled the gas tank a bit over a year ago and the pump and sending unit were fine, and at the same time I replaced the fuel filter with a Wix, and there are no fuel leak smells or indications.
