question bout the no webbing b/w the exhaust port and wastegate port!
MrKnock
Feb 25, 2005
Mundelein, Illinois
hey i had a 18g eliminator turbo and i used a buschur racing o2 dump with it.... okay! i then bought a t3/t4 50 trim not knowing that its an option to get the webbing in between the wastegate port and the exhaust port! why is that, since i bought the 50 trim the dump tube was useless to me and it made me mad when i put it on, the exhaust came out of the dump tube...! does anyone know if you can get the webbing welded or sumthing again or not? does anyone know which is better to have, and if theres a difference? let me know thanks guys!
Are you refer to removing the center divider in the turbine housing? If so some companies started removing the section as a last resort type band-aid in eliminate boost creep. I would think it would be possible to have a welder fill in the divider and grind it smooth, but a more reasonable fix would be to have your wastegate dumped back into the exhaust.
alright thanks man... yea i'm talking bout the divider... i'll prolly jus leave it alone and keep it the way it is, i mean it runs fine i jus miss the o2 dump sound... soo loud!
