question about wiring
billygreenhaw
45
Jul 3, 2011
springfield, Missouri
i am looking to install an alarm light in my car is there a spot in my wiring harness that supllys power with key off but not with key on or ground this way i have looked around on mitchell at the wire diagrams with no luck so ithought to ask some fellow dsmers
Well if you know bosch relays (standard automotive relay) you can wire it from one of them.
The fuel pump relay is constanly powered. So is the ASD relay.
Either one would work. They are located on the firewall BTW.
This is the standard wiring terminal designations for a bosch relay;
87a is powered with the key off on both those fore mentioned relays.
I'm sure either the relays in the car doesn't have the 87a terminal.
Either on the relay or the connector for the relay or both.
You can just add a 5 terminal bosch relay (make sure it's a good one 20 amp rating) Then add the terminal to the connector & use that for your key off power.
