question about timing marks in relation to tdc...when exactly is it considered tdc?
91tizzy
459
Jan 19, 2008
Cincinnati, Ohio
I checked to see if my intake cam was a tooth off because my ignition timing is fully advanced and I was told that is kind of the bandaid solution for the intake cam being a full tooth off...So I pulled the timing cover and used a ziptie sticking in cylinder number one to show me when the piston hit tdc. Now when the pistion first reaches tdc the intake came does appear to be a tooth off. But when its still at tdc and right before it starts the next stroke (right before the piston starts descending) the cam marks appear to be in perfect time.....which should I assume? When exactly is tdc right when the pistion reaches it fullest upward extension or while it is still at full upward extension right before it starts to descend? Any help is always appreciated...
I should have known better than to think I could get away with checking it how I was....was just tryin to get a quick idea without having to get too involved...guess im just gonna give in and go through the dam thing and re-time it so I know its done right
