QuarterMaster Twin Disc in FWD
CJTurbo
84
Mar 16, 2007
Lake Grove, New York
I am curious if any FWDers are running the twin disc clutch from Quartermaster. I am shooting for high 10's with built motor and tranny and have an ACT 2600:notgood: I can not shift at higher rpms without a problem and I can not stand the heavy pedal. I am not concerned with noise as this is mainly a track car with an occasional run around town. I currently have the fidanza aluminum 7bolt. Can I use this flywheel to save a few $$$ or would it impact the performance.
I read that earlier. That basically states that it will not work with the Fidanza flywheel, but it will work with the Quartermaster FW. I was not sure if the OP of that thread had the Aluminum FW or the Billet Steel.
Im running a quartermaster twindisc in my FWD :)
Trans is a shep stage 4 AWD but for a FWD set up, Loving the clutch
You wont be able to use ANY flywheel that you have as the flywheel is specially made for the 7.25" clutch surface.
Compare this to your flywheel should make more sense. THis is for an AWD however there should be no difference the clutch will still ride in the same place.
By Welcome!, shot with Welcome! at 2009-03-09
Maperformance has Alum Flywheels available for twin disk FWDs give Chris a call!!
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
