QM twin disc issues
6bolt_tsi
42
Jun 9, 2008
SLC, Utah
I don't have access to "Drivetrain tech" section so here goes.
Anybody having issues with creep in first gear? The car seems to shift good, but doesn't fully disengage when the clutch is pressed in. I have installed a brand new OEM slave, Autozone Master clutch cylilnder, machined clutch fork, pivot ball, TOB, steel braided clutch line and a twin disc. This was all installed last week. Im at a loss on what to do. The clutch pedal assembly is fine as well. Any ideas? The rod on is adjusted basically all the way out. I don't understand. I have also gone through a full bottle of fluid just bleeding. This is on my 1G AWD Talon.
You might have it disengageing to soon!! It should fully dissengage around 1"-2" from the floor.
  • Wanted 6 bolt NT water pipe
    • chrisman287
