Canadian_CD9A
Supporting Member
- 1,222
- 1,104
- Feb 10, 2012
Winnipeg,
MB, Canada
I got bored and started thinking about how bad our center diff sucks and needs to get away from viscous and clutch-type setups. Yes, that leaves either an open diff (no), welded diff (hell no), and the equally sucktastic Quaife center. The issue with the Quaife, of course, is that it breaks the gear/housing when you look at it wrong. That's a shame because it otherwise fixes our inadequate center diff with an actual torque biasing setup. Given that our 4th gears are also known to suck, the fix is a straight cut gear and diff housing gear. Since we're already doing this, could we fix the Quaife's breakage problem by Boldting one with a straight cut 4th gear?
