Punishment BOV with injen intake install??
Guzman08
989
7
Jun 16, 2009
Valley Wide, Texas
ok so i bought a punishment racing fmic for a 2g. i saw how to install it a bit and kind of get it but i dont know how to install it with a injen intake.. so i need to know how to connect the greddy type bov wastgate actuator j pipe and injen intake. what exactly do i do. what hose connects to what?
this is not my set up and the bov will be recirculated.. so the blue thing is suppose to be my MBC .. the red i know goes connected there.. i just dont know how to hook up the yellow and black parts. what goes where and how.. sorry i have searched but have not found a answer with the intake nipple.. thanks guys.. oh i forgot to add the j pipe nipple in the pic..
The mbc hooks up to the waste gate and j pipe. The nipple on the intake gets capped off.
The greddy bov only uses the top nipple as a manifold pressure source, and the nipple on the bottom can be used as a source to tap for if you have a boost gauge
Woah- wait what? The bottom nipple can be used as a boost source tap??
well thats what people have wriiten on forums but idk.. i just want to know how to hook up everything right
red= is bov to intake manifold.
yellow= ??
blue=is connected to the intake nipple
white= j pipe
black= wastegate
the black and blue are connected with a T tube. . idk if i have it right... can someone please help.. and finally got it recirculated. . . !!!::thumb:
and thats a MBC .. TurboXS
the lower nipple on the bottom of the bov goes directly to a boost source right off of the turbo. I know its probably not proper but i used the same fitting as the mbc for the lower nipple. It basically helps the bov open at low boost.
