pully set up ?
As kidtsi stated, the crank pulley should ONLY be true OE harmonic dampener (not OEM replacement), Fluidamper or the ATI dampener. With the other pulleys you can put on your fancy colored aluminum pieces. I'd recommend that you stay away from an under drive pulley on the alternator as well as that will affect the charging system.
  • Wanted 6 bolt NT water pipe
    • chrisman287
