PTE turbine housing cut divider trick on a 16g question?
I've done it. It does work, but the creep problem can be solved without doing it, by porting the wastegate outlet hole area. I feel that cutting the divider has hurt my power output by affecting the efficiency of the turbo. I have a very peaky looking power curve(DSM Link). Look for posts by Tarantula, he was able to eliminate creep by porting the wastegate hole area.
