Pte internal wastegate question
cherrymane
190
Dec 13, 2012
port richey, Florida
What's I recently purchased a pte 6052 that is internally gated but didn't come with it. So my question what is the sizes of pte turbo internal wastegate that are applicable for mine I have someone that has one foes sale of a bigger 60 series and need to know if it will bolt up to mine? I have a dsm flanged o2 housing on it as we'll.
The kid has a 6152
There are no direct-fit wastegate actuators for T04E and T04S-based turbos because these turbos never came with wastegates from the factory.
PTE welds a T04B wastegate actuator to a T04E hold-down bracket. It's kinda half-assed, but it works fair up to certain boost levels. A while ago I had a bunch of wastegate mounting brackets CNC plasma-cut which completely replace one of the hold-down brackets on a T04E turbo, similar to those used on the Kinetic-built SBR "G-series" turbos from about 5-8 years ago. You can then use a Garrett or Holset universal actuator at whatever boost pressure you desire and just shorten and bend the arm to fit whatever turbine housing you're using. A much more-durable design than PTE's.
