Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
hey guys, i have been looking around. i got a set of the Mitsubishi PTE 1000CC injectors from extreme psi a while back (part # PTE-SCIM1000) i have read on various pages that these injectors ARE flow tested and matched to within 0.5%. although on ECMLinks website they are saying they are flow tested at 940CC. on PTEs website it says all injectors over 580CC are flow tested and matched although i can not seem to find the part number that extreme psi has on PTE's website. their 1000CC injector part number is SCIO950 does that mean flowed for 950? just a little confused as i am hearing both ways
if anyone has gotten their pte 1000CC MITSUBISHI injectors flow tested, how far off were they from the advertised flow rate? should i expect each individual injector to have a different flow rate?
in ECMLink what are you guys setting your global and dead times to for these? ( i know ECM has suggested dead times and global in the Wiki) looking for personal experience with this and haven't been able to find relevant information on a consistent basis.
i currently have my global set at 52% at an estamated flowrate of 940c which is what ECMlink suggests with their calculator in the application and a dead time of 450 usecs. fuel pressure is at 42.5PSI BASE pressure as recommended by ECMLink
i would take these out of my car and bring them to a local shop but they insist on getting these shipped and not on a local drop off. i cant afford to have my car inoperable for that long so thats why im askin here.
thanks in advance!
Links on contradictary info
http://www.jayracing.com/index.php?main_page=product_info&products_id=75
http://www.nolimitmotorsport.com/precision-turbo/fuel-injectors.html
^this one is where i cant find the same part number in the mitsubishi injector secion only shows part SCIM950 and not 1000
http://www.precisionturbo.net/air-f...o-and-Engine-Sport-Compact-Mitsu-Injectors/41
^PTE saying their injectors are flow tested and matched within 1% at 43.5PSI (should i change my base pressure to this instead of 42.6? or does 1 psi not make a difference?)
EDIT:
on extremepsi they have this little bit about deadtimes, how would i apply this to ECMLink? do i need to convert the 2.128MS to usecs?
Response/Dead Time:
- Open Response: 1.13 ms
- Close Response: .998 ms
- Total Response Time: 2.128 ms
thanks in advance!
EDIT:
Response/Dead Time:
.. either that or they are not very helpful. they said they do flow test and flow match their mitsubishi injectors... ALTHOUGH they test them at 85% duty cycle... and said if someone were to test them at 90% it would still only be in the 900CC range.. which is contradictory with ECMLink and also which didnt tell me anything about my question as far as them being accurate.. they were not able to give an accurate flow rate for that specific injector.. just a very generalized "within 100CC"s of the advertized flow rate... Origional post still stands... has anyone had these flow tested themselves? same OP questions still apply..
i was unaware that dead times only really affected idle... i am how ever getting a pretty stable 14ish at idle with 450Usecs of deadtime. i do think global is where i need to manage the WOT pulls because that is where i am leaning out.
