air flow equation
gst1103
Oct 24, 2004
Everywhere, West Virginia
Does anybody know the equation, or if there is one, or a way to convert mas frequency(hz) to air flow in lbs/min..
Unfortunately, the Karman Hz frequency to Airflow relationship is non-linear and is also affected by temperature and ATM pressure. Your ECU has an internal calculator that reads these three factors to determine actual airflow.
There is a THREAD I started a while bach which had interesting disccussions on this topic, which concludes with a note from Jeff Oberholtzer (DSMChips) whom found real Factory Mitsu documentation on such relationships with a 2G MAS which Jeff Lucious puts together graphically HERE :dsm:
