Actuall air flow readings or not???
madman
472
3
Oct 9, 2003
Kansas City, Missouri
I was just thinking about using a S-AFC and or GM MAFT and the affects on the car. They are used to trick the computer into seeing less air flow in order to tune a car with bigger injectors correct?
So does that mean when I do a log and let's say my peak air flow is 21 lb/min, Is that the actuall air flow or am I actually flowing more but it reads lower since the computer is being tricked by my S-AFC? :confused:
That's actually not correct, 1990EclipseGSX. The log already reflects the correction, so you can can't use that number. You need to use a formula that accounts for that.
A / ( 1 - C) = Actual Airflow
where,
A = Peak airflow on logger
C = Correction factor in decimal form at rpm where peak airflow occurred.
Cheers!
where,
Cheers!
Whoops! You are absolutely right. I don't know what I was thinking.
