PTE 50trim return line HELP!!
jongreene
484
6
Nov 3, 2005
midland, Michigan
I know the motor mount bracket needs "trimming".
I have a 45* fitting and the normal straight fitting, which one did you put where?
and how long should the hose be between the fittings?
this has been a major pain , any help is appreciated
Put the 45 on the turbo. so you might not have to trim the motor mount. I went to a hydraulic shop and out the correct size hydraulic grade hose for oil and heat then just clamped them on to the fitting. worked good. I think im going to redo it someday but its been working fine for months now.
edit. i dont think the line was over 12 inches just get a foot of it and trim it to size. actually probably closer to 6 inches, but thats just a guess.
I have my 45 on the turbo also and the is no kinks in the line, 7 1/2 inches of -10 with a 45 on the turbo and straight on the Pan.
Most usually use the 45 on the turbo and the straight fitting on the oil pan. I've eye-balled it and it looks like 2 45's would be the most accomodating, especially with the SS -10an lines. Are you using SS or pushlock? Either way, doing a return line is always a PITA. Goodluck.
I recieved the SBR 50-trim install kit (-10an quick fit, not braided), it included a 45 degree and a straight... I threw away the straight -10an fitting and purchased another 45 degree. The two 45's are a much better solution in my opinion.
c4
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
