Kevin Jewer
DSM Wiseman
- 1,486
- 351
- Jul 25, 2002
LaRue,
Ohio
Just a couple points. Trying to get a reliable repeatable 12 second pump gas car on a 16g is not the easiest thing for the average person to do. Can the turbo do it? Yes. Would I want to? No. About injectors. Sure, poeple can run 9s on 250s or whatever the latest rumor is. But thats on race gas and lean as hell. On pump gas at high boost/airflow however you need a lot more injector than most poeple think. I've maxed out 850s on pump gas in the past. All depends on airflow per rev and target AFR. For some random datapoints, I ran 12.4s on pump gas and a sidemount with a SBR M50, then with a FMIC I ran some 12.1s-12.2s IIRC on the SBR TDO6H 20g. Damn near broke into the 11s on a SBR TDO6H 56 trim, but clutch issues hosed my ETs (12.0x). MPH was 117, more than enough for 11s. On a smaller 60-1 stage 3/.82, I trapped 119, but again couldnt ET worth a shyte. There is certainly more power available with these turbos on pump gas, but finding that power is tougher than it is with race gas. And you have to be careful
The moral of the story is that pump gas power is all about heat. Compressor efficiency plays a part in it, but intercooling efficiency is much more important. To use the extreme example to illustrate the point, with 100% efficient intercooling, compressor efficiency would be irrelevant.
Choose a turbo that flows enough air for your goals, plus some head room. Then focus on intercooling, adequate fuel supply, and then tuning it. And any mods that allow more airflow without raising boost (heat) really help on pump gas (cams, bigger turbine AR/wheel, manifold, stroker, etc).
He did say he would have all the supporting mods.
