PTE 50 Trim
yhype
332
11
Nov 3, 2002
Thurmont, Maryland
I am in the process of building my engine and i am using weisco 9:1 compressino pistons. I am not totally sure that the 50 trim will be a good trubo to match with the 9:1 pistons. Will i be able to run as much boost as say 8.5:1 pistons even with more fuel? my goal is around 400-450hp, i am going to be using magnus intake manifold and and evo3 exhaust manifold. I am thinking i might need to buy a slighty bigger turbo to get to that hp goal but with the higher compression the bigger turbo should spool about the same as a smaller turbo on less compression pistons correct? any help on my thoughts would be great.
A 50 trim will be fine with those pistons, you just need proper engine control and intercooling.
