Demon33
- 296
- 2
- Aug 11, 2008
Southern,
California
I just replaced the input and output shaft seals in my transfer case. I had to open the case and remove the input gear in order to get the input shaft seal out. The output shaft seal came out using a flat blade screwdriver.
After pressing in the new seals, I reinstalled the input/drive gear but later realized that I simply dropped it in without regard to any alignment. I found the following page in the sevice manual and it indicates that there are 'mating marks' on the case and gears.
So my question is, is there any harm in simply dropping in the gear and sealing the transfer case or do I need to align the gears and case first as described in the sevice manual?
My thoughts are since the input and output gears have different tooth counts, it shouldn't matter what position I install the gears in since the gears will mesh in different positions with each rotation. Eventually with enough rotations, they will line up as if I had installed them with the mating marks in the proper position. However, if there gears had the same number of teeth (1:1 ratio) then alignment might matter more since the teeth of each gear would always mesh with same teeth of the other gear. Does this make sense?
