InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
I just found this on HondaTech when looking up info for my JDM Fogs. But Its perfect for this site. This company designs REAL Bi-Xenon Projector retrofit kits for headlights. Not like what we do with cutting and drilling and hacking, Its a housing they designed to fit into the stock headlight bulb socket and screw in. When all is said and done, all you do is heat up the headlights, separate them, put the new housing in, tighten it down, put the headlight lens back on, wire them up, bolt the headlights down and your done! No hacking required, no molding required!
I'm going to order one for the Civic first, and if all is how it seems, I'll order one for the Talon. I can't get over how easy this company makes it. Even the most simple minded person, someone that can't even put a puzzle together, can acomplish real Projector HID's.
Order Here:
Results for Retrofit/Projectors
Pictures:
Not Bad for real Bi Xenon Install Kit that looks soo pleasing, only $230-250!
Order Here:
Pictures:
heaven forbid i misread some information....thanks for the follow up. Im sure there are many members here looking forward to install(ed) pictures.
