project 11s fwd. budget build
I'm keeping an eye on this thread also. Do you have any idea what suspension setup you'll be using? What lb. front and rear springs, what shocks? any valving changes? You don't need a lot of power to run 11's in a FWD 1g. Just a good suspension and some weight reduction...
im buying some megan racing lowering springs and some 26.5/8/15 mickey tompson slicks.and poly urethane mounts all next week..import face off is coming on the 5th so i want to have everything ready
just found out today that i been running a big 16g turbo this entire time..i swear i thought it was a stock 14b i just couldnt figure out were i was making so much power from..so now all i need is more fuel and better tuning and i should be set...
im running at 16 on an evo 9 denso fuel pump.which i think is equivalent to a 190lph
hopefully.... i get full boost up in high rpms a bit laggy but when it finally reaches 16psi its a freak of nature
good luck on your goal i have a similar setup, still need some stuff but i want to see how far i could push the 14b. Plus money isn't there for me right now, trying to find a job.
