profec b owners (w/2G)
Module Unknown
557
Nov 27, 2001
Elk Grove, California
Just wondering where you guys installed that big a** solenoid/box.
So much for hiding the thing. :notgood:
I made a rectangle hole just a bit to the right of the cigarette lighter then used zip ties and epoxy to hold it in. It looks good to everyone else, but i wanna cleaner more flush mounting spot.
In case I wasn't all that clear on it, I'm not talking about the control unit, but the actual boost control solenoid (giant box) that is installed between your boost source and wastegate actuator.
I have the original Profec B, don't know if the Spec II or any other revision of the Profec B are any different.
I put that part behind the power steering resevior. It's hidden pretty well, the feed line to it runs from the manifold right along with teh A/C lines and then from teh box over to the line on the wastegate. I have an external wastegate setup like it would be with a manual BC, i get more stable boost that way. No matter how i set teh dipswitches on the back to run both lines to teh external it never seems to stay as solid.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
