Resolved Problems with cylinder 1
rtincher22085
136
Aug 17, 2010
Rockland, Maine
ok I have injector fire. compression and spark in cylinder 1 but it wont fire. its leaking oil out the exhaust side bad valve seal? cracked ring? head gasket and when I went to crank it over with the hood open it shot the dip stick out about 5 feet LOL i am getting pressure down below and oil leaking out the exhaust HG? HELP please:ohdamn: I made a 20 psi pull when this happened first time it has ever done this
I don't know if this is the right place to be asking this but I have a delema. I made a pull today and my car started to lope I pulled at 20 psi my signature says whats done to my dsm. I have spark, I have fuel , I have compressionbut no fire the piston is moving the plug out there is compression. heres the weird part oil is coming out the exhaust port.Can the HG be the culprit? what test should I do to confirm HG or Ring? thaks any help in the right direction would be the greatest.
Solution
here is my masterpiece
spiked 30 psi and fuel pressure dropped ooooouch EPIC FAIL
That's what you get for running 20-30psi without knowing what is really going on. The piston melted.
Hopefully you'll do you're research for the next motor before you go mashing on the gas and wondering why it's running funny.
Good luck.
Solution
