Problem with TPS adjustment after 1G TB install on my 99
streetdsmpwr
322
3
Oct 13, 2009
Canton, Michigan
First off, I recently installed a 91-94 60mm TB onto my 99 GSX. I transferred my TPS and ISC from by stock TB to the new one like I was supposed to. I use Evoscan 2.8 for data-logging and at wide open throttle, the TPS % is only reading 94%. I thought this might effect my WOT fueling so I adjusted it while logging with Evoscan, so that at WOT it just reads 100%. Now it reads 16.4% at idle which is apparently too much for the car to idle properly and cut the injectors out when decelerating. Is there a way I can have my car idle fine and have my TPS read 100% at full throttle? I assume it did not hurt me too much at the track reading 94% because I tied my best time, but I was hoping for an improvement. Thanks.
Its fine if your tps percentage is around 94% so long as reads between 90% to 100% on your datalogger. There is no proper way to adjust this without having your idle position switch correctly set.
Ok. I think I'm gonna just adjust it so I can get as close as possible to 100% while still trigger the idle position switch.
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
