problem with rear wheels
racker
79
Oct 24, 2007
Miami, Florida
ok, today I change the rear differential and axel because are bad, the new rear diff is good but when i turn to the left o right the rear wheel feels like lock up and the anti lock light become on and dont know if the abs system lock the tires or are another thing.
I'm having a wee bit o' difficulty reading your post, but I can tell you that the ABS on a DSM only has the ability to reduce braking force; it cannot apply the brakes without you pressing the brake pedal.
Are you sure the new parts were compatible with the old ones? I.e. If you had an LSD dif, did you make sure the axles were from another LSD-equipped car?
thanks, for your anwers and yes the rear diff are LSD with the number M8837592 the only thing that change is another number that the olr rear have 4L23 and the new 4l22
