problem with engine motor 4g63t
racker
79
Oct 24, 2007
Miami, Florida
hello my friend's i come to coment my problem, i have a dsm 95 gsx stock, with boost controller only and 12 psi in the turbo, yesterday i here this sound
what can be the problem? :cry:
it kind of hard to say from that video, track down the sound, maybe using a long screw driver and listening to the end, finding out where it is generally comining from is your first step.
pull one wire at a time and see if it goes away/gets better. it sounds like a rod knock to me, but it is hard to tell on video. pull one wire, ground it and start the car, do this for eack cylinder. it definatly deosnt sound like lifter tick. if you have a vacuum gauge, hook it up and see what the needle is doing. most mechanical failure will result in a rapidly moving needle.
I also think you should pull each plug one at a time and see if the noise goes away. Either way it goes it sound like you might need a rebuild.
That sounds like rod knock! The sound even goes with the engine which makes me suspect it even more. The only other thing that makes that noise is lifter tick, but that noise sounds too loud to be lifter tick..
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
