priming turbo?????
jeffreyinigo
65
Oct 6, 2004
Tucson, Arizona
i just swapped out my 13g for a 14b and havent started it yet. it says we should prime the trubo in the writeup. what does this mean to "prime the turbo."
All that means is that you have to run oil and coolant through the turbo before you start it. You have to pull the relay that lets your car start when you turn the key, I can't think of the relay off the top of my head, but just crank the car with that relay out so it won't start, but it still pushes oil through the system. It's just so that when you start the car your turbo has fluid in it and isn't dry. :dsm:
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
