August578
5+ Year Contributor
- 101
- 28
- Jun 15, 2021
Eastvale,
California
So I’m replacing my clutch and my trans is pretty dirty, I’m thinking of cleaning up and painting it while it’s out.
I have a general idea of what to use but couldn’t find a definite answer if I should use primer, and which primer to use.
I’ve never painted anything before so this is the 1st.
I’m planning on using VHT Enamel Cast Aluminum and a clear to help it.
But not sure if I should use self etching,Sandable, etc or no primer at all.
That means I had to take it all apart to clean and check every Bearing and Gear.
