Power Window won't work!?!
craracer05
Supporting Member
357
90
Sep 29, 2005
Warren, Ohio
So i put in some new speakers the other day and while i was at i took the driver's window switch apart to clean the contacts. The reason it would roll the pass. window down but not up. In the mean time the child lock switch i believe thats what it is broke. I put everything back together and now the passenger window won't work at all. I figured the child lock was stuck on now so i jumped the two pins together with a peice wire still no luck. I also metered all the fuses under the dash just to be safe. Should i go get another switch or is there something i'm missing?
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
