power window not working!!! help
TazManianDevil
239
Jul 8, 2003
Lakewood, Washington
:cry: just like the title says my windows are not working! help! both driver and passenger side is not working but the locks inside the car and sunroof are working is there fuse for window? i tried to look for it but i cant find it thanks
i already did that thank you but it didnt help my problem i already search here bout my car windows problem but got no luck :cry: i think that window lock thing beside the door lock works only for passenger side but my problem is both driver and passenger side are not working. Do you think its the motor? how come they die at the same time :confused:
this is the biggest qwinkie dink ever....mine messed up cus my boy put in speakers the other night n we unplugged the switch in the door panel a cpl times ...that night they rolled up when i got home but the next morning it was like 90 degrees out and they wouldnt drop i was pisssst....so i talked to some techs at work and they said its probably a fuse...sure enough thats what it is...i didnt look what kinda car u have but im gonna assume that its the same as mine ....fuse box on the left side if ur facing ur hood...read the top of the plastic....i dont feel like goin n looking but i think its the 4th one from the left on the top row...should say p. window or something...look at the fuse see if it looks like the rest of the fuses with the metal goin from top to bottom...if the metals broke the fuse is blown.... if the fuse is blown go to pep boys...n look for a "30A fuse" u can even pull it out n take it just incase u forget 30A should be on the side of the fuse...plug the new bad boy in n WAAAALAA it should work....good luck...i should get some money for this one... :thumb:
:) guys thanks for the help EclipseGST-95 the fuse was blowned i went to schucks(nearest place) and replace it im glad thats the problem cause after i replace the fuse it rain :D thanks again :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
