power steering resivoir puking every where help!!!!
cemille01
52
Dec 12, 2009
hanover, Pennsylvania
:barf: yep thats what its doin LOL every time you turn the wheel even with the car off !!! ( yes the cap is tight) i filled it up when i did my t belt but maybe i over filled it? didnt know if there was maybe another problem causing this besides too much fluid in the system , but it seems that it has lost more than i even put in, any feed back would b great guys thanks -chad-:thumb:
put the car on jack stands. make sure the resevoir is full keep the cap off to watch the fluid level. crack the bleeder valve and put a hose on it that will fit and put the other end in an empty container. start the car turn the wheel from one side to the other and keep watching the level of fluid. if it goes to low you'll have to start all over again. after you turn the wheel a few times close the bleeder valve and add some more new fluid and youre set. :)
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
