** Power Steering Issue **
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
ok Another question haha. so my power steering has a nasty leak in it some where under the car ive seen from past records that its been patched numerous times and i guess it just isnt work i wanna just take the P/S pump out and block off the lines would this be fine or is it just a really half A$$ thing that will end up with problems. thank you...
brian
Where is you power steering leak? yea. You can just take the pump off and block the lines. More hp.
its kinda hard to tell its leaking around the steering gear assembly. im pretty sure if i take it to a shop they will say replace the whole thing which i dont wanna do and its if it was a small leak then w.e but it makes a puddle everytime i got to sleep and wake up in the morning. when i had my supra i removed the P/S pump and all that and i had no problems some1 just told me a couple days ago that thats not good to do so i need some advice haha
It should do fine. Just take the pump off and plug the lines. I steering gear rebuild kit is 280 and a new steering gear is 1000 from the dealorship.
oh really thats not as bad as i thought thanx alot for helping me with all the questions ive had so far :thumb:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
