power steering pump issue
sunshdw
Jan 27, 2004
Boise, Idaho
Just was wondering if anyone else has run into this problem. While going through some of the quick left to right transitions in auto x it seems my p/s is fighting me. The five races I did last season this was a problem then as well. In attemps to cure this I have tried DSM fluid, mobil one syn and regular fluid with some ER in it. Nothing has worked. I raced an auto cross today and took second by .26 seconds. Needless to say had my p/s worked right I probably would have won. I had read in a forum before that there is a pressure relief valve in the pump. Now removing that would blow up anything the isn't a metal so is there a way to "modify" it?
What RPMs where you running at when you lost power steering. Not sure about the NTs but the T models have a smart power steering system that cuts out at higher RPMs so you have a better feel when racing down the highway.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
