powdercoated cam gears
risknjtsi
Nov 18, 2004
NEWARK, New Jersey
im working on a 95 tsi awd and i cant seem to get spark on cyl 1 and 4 now i took everything out from this car and tried it in my car and everything works ( ecu, ignitor , coil, ) i replaced cam and crank sensor and their both in working order now my question is both cam gears (the motor is a 95-96 cam sensor behind intake cam gear) are powdercoated and the trigger plate on the cam gear is also coated now will the coating cause the cam sensor not to read in which would cause the cylinders not to fire cause i am running out of ideas.
luv2rally gave me his wisdom and said maybe i would like anyone to shine in on my question thank you
