turbotsi92
- 342
- 1
- Sep 15, 2004
Morgantown,
West Virginia
I know the 1st response is going to be search, well I have went through 50 threads, and everyone has either pulled the tranny with the engine which I don't want to do, or they have pulled the head, and just removed the block which I have done before.
My question is can I pull the block and the head together if I remove, intake and exhaust manifolds, crank, water pump pulleys, etc. Will I be able to pull it with a cherry picker because I am just selling the engine, and wanted to leave the rest of it together. Also, it is going to be parked outside all winter so I didn't want to pull the x-case, and the axles leaving everything exposed to the weather.
, yea do like he said just dont leave it outside. Knew a guy who had a fully build stroker and his motor caught fire. He melted the whole top of the head, the thermostat housing was melted to a puddle of metal. Well he then took the head off and left the short block outside in the weather and never covered anything up. He ruined the 2k motor.
) That will bareley give you enough room to seperate the two. then pull the motor out. I dont even take the turbo off much less the intake manifold. Just watch the starter and the ac compressor. People told me I was crazy to do it this way, but I just didnt want to mess with the clutch lines and axels and stuff. The first time I did it, it took about 5-6 hours. Now I can have the motor on the ground in less that 2.(with air tools) And when I put it back in I dont have to do any thing to bleed the clutch reattach shift cables or any thing with the trans. But to each his own. But remember this is a 2g I have not had to pull the motor out of my 1g yet.(Knock on wood)
