Possible to change the actual transistors inside the "transistor module"?
GooeyGus
459
Sep 23, 2009
Marysville, Washington
Hi Everyone,
I was brainstorming tonight, and I wondered if anyone has ever tried to crack open the ignition transistor module and change the actual transistors inside??
A two dollar transistor or two seems a lot cheaper than $100 for a new unit.
Has anyone ever cracked one of these open? Any pictures? I'm sure with a bit of research we could find some matching transistors and we would have a cheaper fix on our hands, if it is possible to get inside the unit to change them.
I have pulled one of them apart and the transistors are welded onto the aluminuim plate ,there is no part # on those peices . the traces are spot welded to the part and the unit is covered in a gel type silicone to restrict water .the parts inside arn,t accessable to the public .
I had a feeling they would do that.
Well I guess I'm just going to try to
make my own then!
Anyone have any idea on the amount of current that flows through those transistors?
On one car that I MegaSquirt'ed, I replaced the transistor pack with a pair of power transistors from Digikey.com. (Directly inside the MS) Basically they are just high-watt NPN transistors that are well-potted. Actually replacing them is easy if you can solder. (Not weld) You can find schematics online.
  • Wanted 1g 6 bolt rear timing cover tins both sides.
    6 boltRear timing cover tins.
    • Robert503
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
