How much time to change the timing belt?
lukb
46
Jul 11, 2011
Frederick, Maryland
How many hours did it take some of you guys to change your timing belt?
I want to get a feel for it before I get it all apart.
I have all the stuff... just picking the right time.
4g63t engine btw.
Really depends on how exerienced you are. I can do one on my car in about an hour and a half max. It also helps to have a cam gear tool, to keep the cam gears in perfect time, and a spanner wrench for when you tighten the tensioner pulley. It's not as bad of a job as most make it out to be, in my opinion.
If the engine is out of the car 10 minutes. With the engine in it should take about an hour if you know what you are doing. If you have never done it before it will probably turn into a 4-6 hour job.
I use the Jay Racing timing belt tools and it takes me about 45 minutes to an hour to change a timing belt.
Edit: With the engine in the car.
First time I did one it took me 3 days. Mainly trying to get the timing cover off. One day just putting the pulleys back on the water pump. Couldn't get all three holes to line up. Finally put some studs in to hold things in place.
Now, takes me about 2-3 hours.
I have done three timing belts and it takes me 2-3 hours. The biggest issue I always have is the tensioner for the AC. My hands are just too big to get the center bolt back in easily. I have found it helpful to put the bolt in a socket and start it that way. The rest is pretty simple.
cool... I guess I just need to plan a couple days just in case...
And could I get a link to some of the tools you guys are talking about?
From the vfaq it just seemed like you could do it by hand!?!
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
