Possible Fuel injector problem
v-mac
231
Sep 7, 2008
Randleman, North Carolina
my car is all kinds of crazy! anyhow my problem is that the car just doesnt boost right, it seems that it lags like i have a boost leak but i do not have one i have checked and had others check multiple times... i have notieced a gas smell for quite sometime never could find the culporate then yesterday noticed that its been a fuel injector cracked the whole time...my question is could this effect the way my car boost, whats happening is when i go into boost it lags and when it does kicka bit its not near the force it should be you cant feel a diff in hp from 5-15psi...i reset the battery drive downt he rd and just on 5psi it pulls very hard, then when the ecu re learns itself my car starts its mess again...so could a injector be the cause of this? i ordered a whole new set alreadyWTF
Stop driving until you replace the injector. Get new seals if they don't come with any and do a proper boost leak test to a number above what you are going to be running. Spray soapy water all over and look for bubbles. Your pressure should hold for at least a minute without leaks depending on how well your internals seal.
Once you replace them and test again, then see if the problem persists and go from there.
